Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster!  It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
In addition to testing under both DirectX 9.0 and DirectX 10 with all quality details set to High, we feel it's about time hardware should be able to handle the game with the in-game settings tuned to Very High.  The game has been out for at least a year now, so it's time for hardware manufacturers to catch up with the software.
We forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game and tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4x anti-aliasing, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction with Very High quality in-game settings, we'll be pushing even the bleeding edge hardware on test to the limit.
        ATI Radeon HD 4870 X2 2GB
        BFG GeForce GTX 280 H2OC
        MSI GeForce GTX 280 HydroGen
        Nvidia GeForce GTX 280 1GB
        Sapphire ATI Radeon HD 4850 X2 2GB
        Nvidia GeForce GTX 260+ 896MB
        ATI Radeon HD 4870 1GB
        ATI Radeon HD 4870 512MB
        Nvidia GeForce 9800 GTX+ 512MB
        ATI Radeon HD 4850 512MB
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
We all know how demanding
Crysis is when the detail is set to very high, and despite the hefty factory overclocks, it's clear that the bottleneck is elsewhere, most likley caused by the limitation of the card's memory bandwidth. Despite their heavy overclock, both watercooled GTX 280s post results just a fraction of a frame per second faster than a stock card.
